[gdal-dev] How to use TransformPoints in python?
Hogendoorn, Rene
r.hogendoorn at hitt.nl
Fri Jan 16 07:31:01 EST 2009
The following simple python script
import os, osgeo, numpy
from osgeo import ogr, osr
def getProjection( EPSGcode ):
""" set a projection from ... to lat-long """
srs = osgeo.osr.SpatialReference()
srs.ImportFromEPSG( 4326 ) # WGS84
ll = srs.CloneGeogCS()
srs.ImportFromEPSG( EPSGcode )
# RD-NL lacks TOWGS84
if EPSGcode == 28992:
srs.SetTOWGS84( 565.237, 50.0087, 465.658, -0.406857, 0.350733, -1.87035, 4.0812 )
return osr.CoordinateTransformation( srs, ll )
if __name__ == '__main__':
proj = getProjection( 28992 )
polygon =[[132817.006604435708141, 550302.852720651309937, 0.],
[131182.28895997320069, 558340.214472591876984, 0.],
[132578.61028128489852, 558748.893883707583882, 0.],
[136631.347774848196423, 553436.061539204441942, 0.],
[132817.006604435708141, 550302.852720651309937, 0.]]
x = numpy.array( [p[0] for p in polygon] )
y = numpy.array( [p[1] for p in polygon] )
z = numpy.array( [p[2] for p in polygon] )
print proj.TransformPoints( len(polygon), x, y, z)
returns:
File "<stdin>", line 37, in <module>
File "/var/tmp/libgdal0-1.6.0-build/usr/lib64/python2.6/site-packages/osgeo/osr.py", line 622, in TransformPoints
TypeError: in method 'CoordinateTransformation_TransformPoints', argument 3 of type 'double *'
I also tried straight python lists of doubles.
So what type of arguments does TransformPoints expect (as there is obviously nothing like double* in python)?
Regards
Rene
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090116/da2f8cec/attachment.html
