[gdal-dev] read non spatial tables using OGR driver
    chen cui
    cui_chan at hotmail.com
    Fri Jan 16 11:18:00 EST 2009
hello,
I know that using
OGRSFDriverRegistrar::Open() we can access and open personal geodatabase .mdb file.
The table with geometry_column will be returned as Layers. But how about non spatial tables inside this
personal geodatabase .mdb file? Or we should use ODBC provider to access those non spatial tables? OGR API does not provide this interface function to access the non spatial tables. I need to read information out of those tables.
thank you in advance for your help.
best regards,
Cui
_________________________________________________________________
Show them the way! Add maps and directions to your party invites.
http://www.microsoft.com/windows/windowslive/events.aspx
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090116/252d71a7/attachment.html
