[gdal-dev] gdal_translate input separate R,G,B output combined
RGB
Roger André
randre at gmail.com
Fri Jan 16 16:39:01 EST 2009
Hi Greg,
I don't know of a gdal_translate command for this, but you can use the
gdal_merge.py tool to do this.
gdal_merge.py - o <outfile> -separate gtif_R.tif gtif_G.tif gtif_B.tif
Roger
2009/1/9 Greg Coats <gregcoats at mac.com>
> I have 3 single band GeoTIF images of the same geographic area: one for the
> Red band, one for the Green band, and one for the Blue
> band, gtif_R.tif, gtif_G.tif, gtif_B.tif. Please, what is the
> gdal_translate syntax http://www.gdal.org/gdal_translate.html <http://www.gdal.org/gdal_translate.html>to
> combine these 3 single band GeoTIF images into 1 three band RGB GeoTIF
> image, gtif_RGB.tif? Greg
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090116/f354099b/attachment.html
