[gdal-dev] Writing a Tiff
Henning Bredel
henning.bredel at uni-muenster.de
Mon Jan 19 09:48:08 EST 2009
On Mon, 2009-01-19 at 20:57 +1100, Michael Sumner wrote:
> Hello,
Hey Mike,
thanks for your exhaustive answere :-)
> Note this recent R-Sig-Geo post about the "in-development" nature of the
> latest builds of rgdal - you need to let us know what versions you are
> using. Also, view the definition of writeGDAL() to see how the lower
> level functions are used.
> https://stat.ethz.ch/pipermail/r-sig-geo/2009-January/004830.html
I have read that message, but my version is not affected be the one
Roger refers to:
> library(rgdal)
Loading required package: sp
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 1.5.2, released 2008/05/29
GDAL_DATA: /usr/local/lib/R/site-library/rgdal/gdal
Loaded PROJ.4 runtime: Rel. 4.6.0, 21 Dec 2007
PROJ_LIB: /usr/local/lib/R/site-library/rgdal/proj
> sessionInfo()
R version 2.7.1 (2008-06-23)
i486-pc-linux-gnu
locale:
LC_CTYPE=en_US.UTF-8;LC_NUMERIC=C;LC_TIME=en_US.UTF-8;\
LC_COLLATE=en_US.UTF-8;LC_MONETARY=C;LC_MESSAGES=en_US.UTF-8;\
LC_PAPER=en_US.UTF-8;LC_NAME=C;LC_ADDRESS=C;LC_TELEPHONE=C;\
LC_MEASUREMENT=en_US.UTF-8;LC_IDENTIFICATION=C
attached base packages:
[1] stats graphics grDevices utils datasets methods
base
other attached packages:
[1] rgdal_0.5-33 sp_0.9-29
loaded via a namespace (and not attached):
[1] grid_2.7.1 lattice_0.17-20
> BTW, you can simplify the writing of GTiffs with writeGDAL() -unless you
> are intending to develop your function to write to the file in smaller
> pieces. The code to do that can be as simple as this:
> library(rgdal)
> ## read in matrix to bm
> ## generate X/Y coordinates - assuming your matrix is aligned as image()
> expects (replace 0 and 1 as needed)
> xx <- seq(0, length = nrow(bm), by = 1)
> yy <- seq(0, length = ncol(bm), by = 1)
> writeGDAL(image2Grid(list(x = xx, y = yy, z = bm))
That snipped brought my machine »to its knees« .. but that is
a problem of R itself (actually, I'm currently exploring).
> But, your R function works for me for the following simple test. As
> Frank mentioned, it probably comes down to a version problem or a file
> size limit (although that seems unlikely since your input matrix "bm"
> must be completely loaded in memory).
> library(rgdal)
> #Loading required package: sp
> #Geospatial Data Abstraction Library extensions to R successfully loaded
> #Loaded GDAL runtime: GDAL 1.6.0, released 2008/12/04
> #Path to GDAL shared files: C:\inst\R\library/rgdal/gdal
> #Loaded PROJ.4 runtime: Rel. 4.6.1, 21 August 2008
> #Path to PROJ.4 shared files: C:\inst\R\library/rgdal/proj
> data(volcano) # matrix 87x61
> bm.writeTiff(volcano, "volc.tif")
> # used (Mb) gc trigger (Mb) max used (Mb)
> #Ncells 305831 8.2 597831 16 407500 10.9
> #Vcells 149194 1.2 786432 6 467409 3.6
> tst <- readGDAL("volc.tif")
> #volc.tif has GDAL driver ltalk X6
> #and has 87 rows and 61 columns
My image got dimension 8950 9790 7, could that dimension
be the problem?
Regards
Henning
. . . no signature
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090119/3d08d8b7/attachment-0001.bin
