[gdal-dev] Using code from the tutorials
    Frank Warmerdam
    warmerdam at pobox.com
    Mon Jan 26 17:40:59 EST 2009
Micke Nordin wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> This is my first post to this mailing list, so I'd first like to take
> the opportunity to say hello to everyone (and I do hope I'm sending
> this to the right list)!
> My question is this:
> I'd like to use some source code from this tutorial:
> http://www.gdal.org/ogr/ogr_apitut.html
> as the starting point for a program I'm writing which will convert
> comma separated text files with coordinates from a total station into
> ESRI shapefiles. Is this all right? And if so, who should be credited
> for writing that piece of code?
> I will release the source code of the finished program under the GPL.
Micke,
I believe I am the author of almost all, or all of the code and text in that
document.  I grant you rights to use and relicense any and all of the
materials in that page as you see fit.
Best regards,
