[gdal-dev] ogr2ogr: KML to any format - export fields
Ednardo Ferreira
ednardof at yahoo.com
Tue Jan 27 14:41:45 EST 2009
Hello!
I'm testing ogr2ogr solution. It's really great.
But I have a problem. The situation is:
1) I have a Map Info Line layer. It has 7 descripition fields.
2) Using ogr2ogr tool, I generated a KML file from this Map Info layer. It's ok.
3) When I use this KML in google earth, the informations are all there.
4) But, If I try to convert this KML to any other format (as SHP or TAB), the 7 fields are all put together in one single field.
5) how can I convert from KML to, for example, SHP or TAB, keeping all fields?
Até mais!
Jesus te ama e Ele vai voltar!
Ednardo de Oliveira Ferreira
Analista de Sistemas e Mestre em Transportes
+55(61)8128-7950
Blog: http://vilaperi.blogspot.com/
Desmascarando o panfleto Veja: http://luis.nassif.googlepages.com/home
Caso Daniel Dantas: ttp://www.cartacapital.com.br/app/materia.jsp?a=2&a2=6&i=1643
“Suspeitavam que eu vivia intensamente e num livre abandono à felicidade; isto não se perdoa." (Albert Camus)
“Quem confia em traidores a si próprio atraiçoa." (Mariano da Fonseca)
"Há o suficiente no mundo para todas as necessidades humanas, não há o suficiente para a cobiça humana." (Mahatma Gandhi)
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090127/4f998357/attachment.html
