[gdal-dev] how to find gdal_fillnodata
Frank Warmerdam
warmerdam at pobox.com
Wed Jan 28 12:15:04 EST 2009
Bryan Keith wrote:
> Hello,
> I combined two DEM datasets with gdal_merge, and there's a broken strip of
> nodata between the two. What gdal utility can I use to fix this? I found
> references to gdal_fillnodata on the web, but I don't have it. I
> installed FWTools 2.2.8 on windows, but that doesn't seem to include
> gdal_fillnodata either. On Linux I have GDAL 1.4.4.0, released
> 2007/11/23. I looked at the source code (from the daily svn snapshot),
> and it looks I need gdal.FillNoData but that's not part of the bindings
> that I have on either Windows or Linux. How can I get this utility or is
> there another utility that I can use?
Bryan,
This utility only exists in the most recent builds from trunk. I see it
was not in FWTools 2.3.0, but it is in the gdal-dev package of OSGeo4W.
On linux you could build from svn with python support and you should have it.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
