[gdal-dev] Build failure on Mac X
jluis at ualg.pt jluis at ualg.pt
Sun Jul 5 14:25:54 EDT 2009
Even,
Since it was a long time from last built I had actually rerun the
configure but did not do a make clean (I normally do it at the end a
building session). I looks like I had forgotten the other time.
Everything fine again, thanks.
Joaquim
> Did you happen to 'svn update' and just 'make' ? If that's the case, you
> should do a 'make clean' before trying 'make' again
> Le Sunday 05 July 2009 18:20:31 jluis at ualg.pt, vous avez écrit :
>> Hi,
>> I do this very rarely but it had worked before. However, today's
>> attempt to build trunk on OSX is failing at the end with
>> b/libNCSUtil.dylib -lmfhdf -ldf /usr/local/lib/libsz.dylib
>> /usr/local/lib/libnetcdf.a -ldl -lcurl -lssl -lcrypto -lz
>>    -install_name  /usr/local/lib/libgdal.1.dylib
>> -Wl,-compatibility_version -Wl,15 -Wl,-current_version -Wl,15.0
>> Undefined symbols:
>>    "OGRGeometry::dumpReadable(__sFILE*, char const*) const", referenced
>> from: vtable for OGRMultiPointin ogrmultipoint.o
>>        vtable for OGRMultiLineStringin ogrmultilinestring.o
>> ld: symbol(s) not found
>> collect2: ld returned 1 exit status
>> make[1]: *** [libgdal.la] Error 1
>> make: *** [check-lib] Error 2
>> Joaquim Luis
>> This message was sent using IMP, the Internet Messaging Program.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
