[gdal-dev] Blocksize in VRT files
Even Rouault even.rouault at mines-paris.org
Wed Jul 8 17:51:17 EDT 2009
For WarpedVRT, there are the BlockXSize and BlockYSize elements that can be
changed in the .VRT file.
For regular VRT, you can't, although it might be desirable in some case of
specifying it also.
Le Wednesday 08 July 2009 22:35:56 Ozy Sjahputera, vous avez écrit :
> I have been using the VRT format a lot lately and loving it!
> I created the VRT files in two ways:
> 1). directly writing the XML file (usually using SimpleSource or
> ComplexSource)
> 2). using GDALAutoCreateWarpedVRT()
> I found out that the VRT files created using the first method has
> blocksize of 128x128. While VRT files created using
> GDALAutoCreateWarpedVRT() has blocksize of 512x128.
> Is there a way for the user to specify VRT file blocksize when creating
> the file using the two methods above?
> Thanks
> Ozy
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
