[gdal-dev] Potential bug with the create function for the "GTiff"
driver
Adeel Raza
adeel.raza at crc.gc.ca
Thu Jul 9 12:25:20 EDT 2009
Hi Frank,
I used gdalinfo.exe and it seems that the TIFF file has been created
properly but the debugging environment is reporting the variables
incorrectly. Thanks a lot for your help.
Best Regards,
Adeel Raza.
Frank Warmerdam wrote:
> Adeel Raza wrote:
>> Hi Frank,
>> To answer your questions:
>> - " I presume you inspected the member values in the visual studio
>> debugging environment? I suspect you have some sort of versioning
>> mixup - perhaps you have compiled your mainline using a different
>> version of the include files than correctly apply to the DLL you
>> end up invoking. "
>> Yes I did inspect the member values in the visual studio debugging
>> environment. I'm not exactly sure what you mean by the second line,
>> but if you mean that my DLL has been compiled from a different
>> version of GDAL than from my import library than that is incorrect. I
>> compiled both the import library and the DLL using the gdal 1.6.1
>> source code and I set the MSVC_VER variable to 1500 in the
>> "nmake.opt" file so that the "nmake /f makefile.vc" file would
>> compile the library for the MSVC9.0.
> Adeel,
> I was suggesting any number of possible mixups though this is
> unlikely to be the case if you have one and only one version
> of GDAL on your system.
>> - " Alternatively, the debugger is getting confused
>> due to different structure packing options being used in your
>> main project compared to what was used in building GDAL itself. "
>> I have no idea what the structure packing options for GDAL or my
>> project are or how to find out what they are? Any pointers in this
>> area would be useful.
> I'm no expert on how visual studio handles such things.
>> - "Is the created TIFF correct (if you close it)?"
>> No. I used GDALClose() to close the .tif file and then I opened it
>> using GDALOpen() and most of the data members retained their original
>> values except the following data members which changed to the
>> indicated values:
>> nBands = 19036392;
>> bShared = 19076432;
> Please, inspect the resulting file with gdalinfo. I assume
> the visual studio reports on GDAL objects will be wrong regardless
> of closing and opening files.
> In general I have learned to be suspicious of debugging environments
> ability to accurately report the contents of variables, and objects.
> Particularly when they are really "owned" by another compilation unit
> - such as coming from a DLL. I have had bad experiences with visual
> studio and gdb/dbx on unix.
> Best regards,
