[gdal-dev] gdal NITF complex driver question
Even Rouault
even.rouault at mines-paris.org
Thu Jul 9 17:07:58 EDT 2009
Shawn,
I'm not surprised. Someone already provided quite the same patch in
http://trac.osgeo.org/gdal/ticket/2526 but I had a doubt about missing
swapping of real and imaginary fields. As I couldn't test not having test
data, this wasn't applied.
Could you also apply the attached patch to nitfimage.c (from trunk) and
confirm if it does correct byte-swapping ? Anyway, attaching test data to the
above ticket would be really great to avoid blind guessing !
Best regards,
Even
Le Thursday 09 July 2009 22:40:11 Gong, Shawn (Contractor), vous avez écrit :
> hi list,
> We made a slight modification in gdal/frmts/nitf/nitfdataset.cpp to add
> support for RADARSAT-2 NITF Single Look Complex format.
> in NITFRasterBand::NITFRasterBand( NITFDataset *poDS, int nBand )
> /* Translate data type(s).
> added:
> else if( psImage->nBitsPerSample == 64
> && EQUAL(psImage->szPVType,"C") )
> eDataType = GDT_CFloat32;
> However we found that the real and imaginary fields come out switched.
> i.e. the gdal driver put Q in front of I.
> We used OpenEV and gdal_translate to confirm that.
> Any thoughts and help are appreciated.
> thanks,
> Shawn
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090709/a0c631be/nitf_complex_byte_swapping.bin
