[gdal-dev] CSV filesize and OVF
Frank Warmerdam
warmerdam at pobox.com
Fri Jul 10 11:09:04 EDT 2009
bartvde at osgis.nl wrote:
> Hi list,
> I've got a CSV file with about 50.000 lines.
> Running ogrinfo on it directly goes smoothly, but if I access it using an
> ovf file it won't work.
> It will work if I split up the large file in 2 files.
> Is there a known limit I am running into?
Bart,
I have no idea why this would happen. Perhaps you could file a ticket
and point to the data and we could dig into it.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
