[Gdal-dev] mean of pixel stack
Neil Best
nbest at ci.uchicago.edu
Tue Jul 14 11:19:42 EDT 2009
Greg Fiske wrote:
> Does anyone have some code (or methodology) that they are willing to share
> that will take a stack of images and return the mean or std dev. of each
> pixel stack (pixels that occupy the same space), while ignoring a user
> define pixel value?
Greg, I am pretty sure that you could do this in GRASS by first applying
MASKs to your input layers so that the values that you want to ignore appear
NULL and then use r.series method=average, off the top of my head. Of
course this might mean installing GRASS, loading your data, etc. Are you
comfortable with that prospect? I can help you with that off-list if you
like.
Neil
View this message in context: http://n2.nabble.com/mean-of-pixel-stack-tp3240160p3257397.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
