[gdal-dev] gdalbuildvrt and nulls again - now from Photoshop
William Kyngesburye woklist at kyngchaos.com
Tue Jul 14 14:50:14 EDT 2009
On Jul 14, 2009, at 1:28 PM, Even Rouault wrote:
> Le Friday 10 July 2009 21:14:18 William Kyngesburye, vous avez écrit :
>> This time I'm taking some Photoshop-created tiffs that I georeference
>> with a TFW.  These tiffs I save with transparency mask (not layers)
>> to
>> handle nulls.
>> Reported by gdalinfo, they appear as:
>> Band 1 Block=12775x5 Type=Byte, ColorInterp=Red
>>   Mask Flags: PER_DATASET ALPHA
>> Band 2 Block=12775x5 Type=Byte, ColorInterp=Green
>> Band 3 Block=12775x5 Type=Byte, ColorInterp=Blue
>> Band 4 Block=12775x5 Type=Byte, ColorInterp=Alpha
>> But when I run gdalbuildvrt on them, they are skipped:
>> gdalbuildvrt does not support heterogenous band numbers. Skipping
>> [sometiff].
> This warning means that you are giving a list of datasets that don't
> have the
> same number of bands. For example, if the first dataset examined by
> gdalbuildvrt has only 3 bands, it will ignore any further dataset
> whose band
> number is not 3. (if the error message isn't clear, you're welcome
> to suggest
> a better one)
Ah, yes, some of the images don't have nulls, and so I didn't save the
transparency.
Is it to generate the vrt with mixed rasters?  Maybe merge the vrts of
one set of no-null rasters and one set of rasters with nulls in a text
editor?
Is there a technical reason (in the vrt format) that gdalbuildvrt
can't mix 3-band (no nulls) and 4-band (nulls) rasters?  Or is it just
rejecting the mismatches for simplicity?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
