[gdal-dev] Failed to process SRS definition
Jørn Vegard Røsnes
jorn at spacetec.no
Thu Jul 16 04:14:27 EDT 2009
Hi again,
On Wednesday 15 July 2009 13:12:38 Jørn Vegard Røsnes wrote:
> Hi all,
> can you see the problem (this works with proj4)?
> It works if I remove "+a=6378273" from proj4-string, but I assume the
> output will be wrong.
> ./ogr2ogr -s_srs EPSG:4326 -t_srs "+proj=stere +lat_0=90 +lon_0=315
> +lat_ts=70 +units=m +a=6378273 +e=0.081816153" -f "ESRI Shapefile"
> gshhs_land_stere ~/download/gshhs_1.3_shapefiles/gshhs_land/
I have downloaded v1.6.1, added some debug and compiled (--enable-debug).
It seems that
ogr/ogr_srs_proj4.cpp OGRSpatialReference::importFromProj4, line 847 - 945
does not read the +e proj4 parameter (neither +f and +es), ref. page 9 in
proj4 doc (ftp://ftp.remotesensing.org/proj/OF90-284.pdf).
+b and +rf is read by the code, so maybe there is a math. workaround?
cheers
Jørn Vegard
> All binaries (proj4, ogr2ogr) from FWTools 2.0.6
> cheers
> Jørn Vegard
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
