[gdal-dev] Converting raster pixel space to geospace
Even Rouault
even.rouault at mines-paris.org
Thu Jul 16 14:43:39 EDT 2009
Le Thursday 16 July 2009 10:41:02 Smart, Gary, vous avez écrit :
> But how do I load a OGRSpatialRef object with the output from the
> GDALApplyGeoTransform? Presumably I can prime the OGRSpatialReference
> using the result of GDALDataset::GetProjectionRef?
Yes, almost. See below
> I'm not yet sure of my
> terminology but is the GetProjectionRef supposed to satisfy the OGR
> importFromWkt (the types seem to clash though - char* vs char**)?
Maybe the doc of OGRSpatialReference::importFromWkt() (see
http://gdal.org/ogr/classOGRSpatialReference.html#b74cfc985bd05404a4c61d2d633a6343)
isn't clear enough ? I must confess that the prototype is a bit weird. You
don't pass the string itself, but a pointer to a string. The pointer will be
modified to point to the remaining (unused) input, what you generally don't
care about.
Ok, here's a sample snippet :
OGRSpatialReferenceH hSRS = OSRNewSpatialReference(NULL);
const char* pszWkt = GDALGetProjectionRef(hDS);
OSRImportFromWkt(hSRS, (char**) pszWkt);
(For the purists, a more correct prototype of importFromWkt () would have
relied on 'const char**' to avoid the above cast)
But a simpler approach would be just :
OGRSpatialReferenceH hSRS;
hSRS = OSRNewSpatialReference(pszWKT);
which instanciates the OGRSpatialReferenceH object and call internally
importFromWkt()
> I suspect my output projection could then be set up with
> SetWellKnownGeogCS("WGS84") in order to convert from whatever input
> projection prevails, to a standard WGS84 lat/long representation (using
> OGRCreateCoordinateTransformation::Transform)?
Yes. Actually, it will be long/lat in term of the order of the coordinates.
