[Gdal-dev] GDAL and ECW
Daniele Romagnoli
daniele.romagnoli at geo-solutions.it
Mon Jul 20 09:58:48 EDT 2009
we have already done it for ImageIO-Ext (a Java project which uses GDAL).
You can take a look on the Imageio-ext setup guide which is available at
[1].
It contains instructions to setup and build GDAL to support several external
formats, as well as instructions to build the java project.
You don't need to read all the guide but you could take a better look to the
following sections:
2.7.1.3, 2.7.2.4 , 2.7.3 (Only the introduction, no need to proceed with
2.7.3.1).
Hope this helps.
Regards,
Daniele
[1]:
https://imageio-ext.dev.java.net/files/documents/7505/124115/ImageioExt-SetupGuide.pdf
On Mon, Jul 20, 2009 at 3:50 PM, jteasis <jdt113 at msstate.edu> wrote:
> I looked at the gdal website about hooking up ECW with GDAL on windows but
> it
> says it needs to be done. Who can do this and where do I get these
> instructions?
> Even Rouault wrote:
> > Le Thursday 16 July 2009 18:08:33 jteasis, vous avez écrit :
> >> I am working towards getting a program using ECW and other formats. I
> >> have
> >> gotten my GDAL 1.5.4 to install with the rest but ECW is giving me
> >> problems. I was wondering if there was somebody who could help me figure
> >> out how to compile GDAL with ECW correctly. I would greatly appreciate
> >> it.
> >> Thank you.
> > See http://trac.osgeo.org/gdal/wiki/BuildHints, section 'External
> Library
> > Issues'.
> > You could also fetch precompiled binaries with ECW support. See
> > http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries (not all of them
> > have
> > ECW support, but some yes)
> > And note that the latest stable version is GDAL 1.6.1.
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://n2.nabble.com/GDAL-and-ECW-tp3268583p3288913.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
Eng. Daniele Romagnoli
Software Engineer
GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
Italy
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
http://www.geo-solutions.it
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090720/9fa44d7a/attachment.html
