[gdal-dev] Re: Problem building gdal library using OCI
Peter J Halls
P.Halls at york.ac.uk
Mon Jul 20 11:37:02 EDT 2009
Srikanth,
check the path config is generating (config.status) for the library area and
correct it, if necessary. On Solaris I seem to remember that it added a suffix
(rdbms?) to the path I specified and so could not find the libraries.
Peter
Srikanth wrote:
> Dear All,
> I am trying to build gdal library on windows using Cygwin with OCI support.
> I have Oracle client installed on my machine and ORACLE_HOME is set. I
> have enabled the oci support using --with-oci=yes and even provided
> -include and -lib paths.
> It is able to locate the include files but is not able to find the libraries.
> error thrown:
> checking if Expat XML Parser version is >= 1.95.0... yes
> checking for SQLConnect in -lodbc... no
> checking for SQLInstallDriverEx in -lodbcinst... no
> checking for Oracle OCI headers in C:/oracle/product/10.2.0/client_2/rdbms/publi
> c... yes
> checking for Oracle OCI libraries in C:/oracle/product/10.2.0/client_2/lib... no
> t found
> checking if Oracle support is enabled... no
> checking Checking for DODS... disabled
> checking for curl-config... no
> checking for SQLite3 library >= 3.0.0... not found
> checking Checking for DWGdirect... disabled
> configure: IBM Informix DataBlade not supported.
> configure: checking whether we should include ESRI SDE support...
> ESRI SDE support not requested.
> I am also attaching the config.log file for you reference. My
> understanding by looking at the log file is it is not able to locate
> libclntsh library.I am not able to find the equivalent library on
> windows.
> Any help in this regard is appreciated.
Peter J Halls, GIS Advisor, University of York
Telephone: 01904 433806 Fax: 01904 433740
Snail mail: Computing Service, University of York, Heslington, York YO10 5DD
This message has the status of a private and personal communication
