[gdal-dev] Problem closing VRT GDALDataset *
    Adeel Raza
    adeel.raza at crc.gc.ca
    Tue Jul 21 16:13:53 EDT 2009
Hi Frank,
Thanks for the help. It seems like you were correct. When I dereference
the MEM dataset the post-decrement reference count is not 0. My question
is: do I not close the MEM dataset since its reference count is not 0?
Best Regards,
Adeel Raza.
Frank Warmerdam wrote:
> Adeel Raza wrote:
>> Hi,
>> I 'm using the GDALAutoCreateWarpedVRT() function to warp a MEM
>> GDALDataset. When I use the GDALClose() function to close the source
>> (MEM) dataset nothing happens. However, when I close the warped (VRT)
>> dataset using GDALClose() I get the following error:
>> "Unhandled exception at 0x01226b6e in Import Routine Test.exe:
>> 0xC0000005: Access violation writing location 0x238dd369."
>> What could be going wrong?
> Adeel,
> I believe the problem is that the MEM dataset is getting destroyed twice.
> GDALAutoCreateWarpedVRT() adds a reference to the passed in dataset to
> indicate that something other than the main application code is also
> using
> that dataset.  But the GDALClose() will close it regardless of additional
> references.
> The safer way is:
>     if( GDALDeferenceDataset( hMemDS ) == 0 )
>         GDALClose( hMemDS );
> In your particular case you know the VRT will hold a reference, so it
> would
> be sufficient for you to drop your reference on the dataset using
> GDALDereferenceDataset().
> Best regards,
