[Gdal-dev] compiling GDAL on solaris - error?!
mdekauwe
mdekauwe at gmail.com
Thu Jul 23 17:44:32 EDT 2009
I tried your suggestion and I got exactly the same error?!
Thanks though, any other thoughts?
Even Rouault wrote:
> Might be a libtool issue. Try ./configure --without-libtool
> Le Thursday 23 July 2009 23:06:39 mdekauwe, vous avez écrit :
>> Hi,
>> Would anyone be able to point me in the direction of a solution to my
>> build
>> error on Solaris?
>> gmake libgdal.la
>> gmake[1]: Entering directory `gdal-1.6.0'
>> gmake[1]: *** No rule to make target `gdal-1.6.0/frmts/o/*.lo', needed by
>> `libgdal.la'. Stop.
>> gmake[1]: Leaving directory `gdal-1.6.0'
>> gmake: *** [check-lib] Error 2
>> I have no idea why it doesn't know how to build the libraries, any
>> suggestions would be much appreciated!!
>> Thanks
>> Martin
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
View this message in context: http://n2.nabble.com/compiling-GDAL-on-solaris---error-%21-tp3312297p3312449.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
