[gdal-dev] Problem with nodata values
Rainer M Krug r.m.krug at gmail.com
Fri Jul 24 09:20:33 EDT 2009
Hi
I have a geotiff and want to use gdalwarp to warp to it into a
different projection.
I do the following:
gdalwarp -s_srs EPSG:32734 -t_srs '+proj=longlat +ellps=WGS84
+no_defs' Outeniqua.tiff Outeniqua_wgs84.tiff
The problem is, that in Outeniqua_wgs84.tiff, the nodata values from
Outeniqua.tiff become translated into -9999. In addition, the areas
new to Outeniqua_wgs84.tiff (due to the warping) become 1.
Which options do I have to use to keep the nodata values and to make
the values of the "new areas" also as nodata values?
Thanks
Rainer
Rainer M. Krug, Centre of Excellence for Invasion Biology,
Stellenbosch University, South Africa
