[gdal-dev] Java bindings RuntimeException
Even Rouault
even.rouault at mines-paris.org
Sun Jul 26 13:02:37 EDT 2009
Sascha,
I guess you are compiling with GCC ? If so, it appears that I accidently
removed some weeks ago a very important compilation flag that I added a few
months ago, namely -fno-strict-aliasing, that is necessary when compiling
with -O2. It appears that SWIG generates not-so-correct code in regards to
the C standard in the upcast methods ( *(foo**)&a = *(bar**)&b ) that the
compiler can happily completely remove !
See http://trac.osgeo.org/gdal/changeset/16006 for the revision where it was
introduced and http://trac.osgeo.org/gdal/changeset/17456 where it has come
back.
Thanks for reporting this !
Best regards,
Even
