[gdal-dev] Re: Possible error in the commit 14983
Daniel Morissette dmorissette at mapgears.com
Mon Jul 27 10:11:30 EDT 2009
Hi Chaitanya,
Good catch! Yes, this was a silly mistake, the line should have been
above the break. I have fixed this in the master version. Will you apply
this fix in the OGR copy or should I do it?
Daniel
Chaitanya kumar CH wrote:
> Daniel,
> You added some code in MIFFile::AddFieldNative() in mitab_miffile.cpp in
> the revision 14983
> <http://trac.osgeo.org/gdal/changeset/14983/trunk/gdal/ogr/ogrsf_frmts/mitab/mitab_miffile.cpp>.
> In the line 1742 of the new version, the statement "m_nVersion =
> MAX(m_nVersion, 900);" comes after the "break;" making it unreachable.
> Can you check if it is desirable? Shall I move it to above the "break;"
> statement?
> Best regards,
> Chaitanya kumar CH.
Daniel Morissette
http://www.mapgears.com/
