[Gdal-dev] default pixel size in gdalwarp
agnes123 agnesyipck at gmail.com
Tue Jul 28 07:30:31 EDT 2009
Dear all,
i have one question on the default pixel size in gdalwarp.
In gdalwarp, we can use -tr to determine output pixel size in x and y
direction, however, if i omit the argument -tr , gdal will have a default
pixel size value which is in target projection units.
For example, if the orginal input raster which has geodetic projection with
pixel size 0.000277778 (decimal degree), after projecting to Lambert
Conformal Conic without typing the argument -tr, gdal will have output
raster pixel size 28.793808m. What is the algorithm behind to obtain the
value 28.793808?
I was wondering if there is somebody who knows it. I would greatly
appreciate it.Thanks!
Regards,
Agnes
View this message in context: http://n2.nabble.com/default-pixel-size-in-gdalwarp-tp3341802p3341802.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
