[Gdal-dev] gdal/ogr/proj and NAD83(CSRS)
Matt Wilkie
maphew at gmail.com
Tue Jul 28 13:25:07 EDT 2009
Let's see if I have this straight then: if I specify -t_srs epsg:4617 and not
+nadgrid, no datum transformation occurs, even though the output .prj file
says it has?
-matt
Francesco P. Lovergine wrote:
> On Fri, Jul 24, 2009 at 09:09:27AM -0700, Matt Wilkie wrote:
>> Now back to GDAL and related projects: does the fact that there is no
>> proj4
>> NAD83(CSRS) datum parameter mean the X-to-NAD83(CSRS) transformation is
>> not
>> happening?
> AFAIK for Canada you can download the freely available NTv2 file from the
> CSRS database and use it with the +nadgrid parameter, if your
> application requires high precision fitting.
View this message in context: http://n2.nabble.com/gdal-ogr-proj-and-NAD83%28CSRS%29-tp3311110p3344691.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
