[gdal-dev] fail gdal autotest rev-17474
Frank Warmerdam
warmerdam at pobox.com
Tue Jul 28 23:44:38 EDT 2009
Brian Hamlin wrote:
> its SegFaulting at gcore/mask.py mask_5
> http://paste.debian.net/42924/
Brian,
I'm not seeing that problem here. This this just happen to you recently
after things were working? Are you using an external system libtiff? If
so, the problem may be that the test exposes bugs in older libtiffs.
Building with an internal libtiff may be more appropriate for the test
suite.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
