[gdal-dev] merge with gdalwrap
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Thu Jul 30 14:10:35 EDT 2009
I tried gdal_merge.py but I got a memory Error because I use the -n nodata
value option. Several threads sugest that I must use gdalwrap instead.
This behavior of gdal_merge.py is very important to me in this particular
case
"In areas of overlap, the last image will be copied over earlier ones".
Does gdalwrap has the same behavior? (I ask because it is difficult to
test and validate with my data)?
Also, the doc says "Mosaicing into an existing output file is supported if
the output file already exists."
But how? What is the option to append data? When launching a command for
another image it says that I must delete the output file.
I would appreciate if someone could validate if this
gdalwarp -srcnodata -3.4028234663852886e+38 -dstnodata
-3.4028234663852886e+38 -of "GTiff" EstRN.img icu.tif
is the equivalent of this
gdal_merge.py -n -3.4028234663852886e+38 -o icu.tif -of "GTiff" EstRN.img
EstSh.img
It works but maybe some more parameters are important.
Thanks for your help,
Steve
Steve Toutant, M. Sc.
Analyste en géomatique
Secteur environnement
Direction des risques biologiques, environnementaux et occupationnels
Institut national de santé publique du Québec
945, avenue Wolfe
Québec, Qc G1V 5B3
Tél.: (418) 650-5115 #5281
Fax.: (418) 654-3144
steve.toutant at inspq.qc.ca
http://www.inspq.qc.ca
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090730/72e65c08/attachment.html
