[gdal-dev] OGR OCI Driver improvement
Fri Jul 31 16:56:34 EDT 2009
Nicolas Simon wrote:
> Franck,
> 	I'm interested in becoming a longer term contributor for the OCI driver.
> 	What format do you prefer for fixes ?  Patch format against main trunk ?
Nicolas,
An "svn diff" patch against trunk is the most convenient form for
patches.
> 	I 'll also provide test to demonstrate the problem and the fix.
> 	Is there a standard way to provide test suite ?
There is a standard form for test suite entries, but for the
purposes of demonstrating things I'm flexible.  The test suite
is in Python so if you needed to script a demonstration doing
it in Python would be convenient.
FYI, the existing oracle suite suite script is at:
  	http://svn.osgeo.org/gdal/trunk/autotest/ogr/ogr_oci.py
Best regards,
