[gdal-dev] reload of layer definition without closing dataset
Even Rouault
even.rouault at mines-paris.org
Thu Jun 4 17:38:50 EDT 2009
You can't. By doing OGR_DS_ExecuteSQL, you by-pass OGR and it cannot know that
you have altered the definition. Reloading is the only safe solution.
Proper fix : add support for a DeleteField() method at the OGR Layer level.
See http://trac.osgeo.org/gdal/ticket/2671. It would require someone pushing
a RFC on that.
Le Thursday 04 June 2009 23:34:09 godofredo contreras, vous avez écrit :
> Hi:
> I'm trying to implement a reestructure layer routine for database
> datasources. I'm using OGR_DS_ExecuteSQL to send a drop column statement to
> mysql dataset and it works correctly, it drops the column but the problem
> is that the layer definition stays the same, how can I force the reload of
> layer definition without closing and opening the dataset?
> Regards
> Godofredo Contreras
> _________________________________________________________________
> Lauren found her dream laptop. Find the PC that’s right for you.
> http://www.microsoft.com/windows/choosepc/?ocid=ftp_val_wl_290
