[gdal-dev] Python Scripts
Bryan Keith bryan at ideotrope.org
Fri Jun 5 13:58:12 EDT 2009
kss,
That's in the gdal-dev branch (I don't really know my way around the doe
repository).  I use both Windows and Linux, and as I recall, it was easier
for me to get it running in Windows using the OSGeo4W installer then to
rebuild on Linux.
I know that's not much info, but maybe it's helpful.
Bryan
> Hello all,
> I am using some srtm data for some modeling and I need to get rid of the
> no
> data values.  I checked the trac and found gdal_fillnodata.py.  Seems like
> a
> good fit, but that script wasn't installed when I built 1.6.1.  Is this
> script out of date, replaced or available in another form, or do I need to
> rebuild differently?  Thanks.
> kss
> Kyle Shannon
> Physical Science Technician
> RMRS Fire Sciences Lab
> Fire, Fuels & Smoke - RWU 4405
> 5775 Highway 10 W.
> Missoula, MT 59808
> (406)829-6954
> kshannon at fs.fed.us
> ksshannon at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
