[gdal-dev] Incorrect use of MEM driver?
Even Rouault
even.rouault at mines-paris.org
Fri Jun 5 16:38:57 EDT 2009
Instead of sprintf("%p"), use CPLPrintPointer() that will add then
necessary "0x" prefix in the case of the MSVC runtime library.
Le Friday 05 June 2009 21:51:20 Gregory, Matthew, vous avez écrit :
> My pointer address is something like 0x00126324. When formatted into
> the filename string, it becomes 00126324 (without the '0x'). Then, in
> CPLScanPointer, it skips the MS specific code (lines 877-886) and calls
> CPLScanULong which returns 126324, which I think is causing the bad
> pointer.
