[gdal-dev] howto flattening of 3D shapefiles
Even Rouault even.rouault at mines-paris.org
Sun Jun 7 08:06:04 EDT 2009
Wolfgang,
There are at least 2 ways of achieving this :
- use -nlt flag of ogr2ogr. For example if your src.shp contains 3D points :
ogr2ogr dest.shp src.shp -nlt POINT. See http://gdal.org/ogr2ogr.html
- or, equivalently, use the SHPT creation option of the Shape driver : ogr2ogr
dest.shp src.shp -lco SHPT=POINT. See http://gdal.org/ogr/drv_shapefile.html
Le Sunday 07 June 2009 13:52:22 WolfgangZ, vous avez écrit :
> Hi,
> I hope that I'm on the correct mailing list. Otherwise please excuse my
> posting here.
> How can I flatten a 3D shapefile? The problem is, that a software, where
> I need to import my shapefile, does not handle 3D shapfiles and
> therefore it can only display 2D shapefiles. However my shp is generated
> automatically and there is no option to flatten the shapes.
> I just had a look at ogr2ogr but I did not figure out how to do this
> task. Any ideas?
> Best regards
> Woflgang
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
