[gdal-dev] shp-gpx conversion with ogr2ogr
Mon Jun 8 13:02:47 EDT 2009
flavio rigolon wrote:
> Hi all,
>  I'm trying to convert a SHP file to GPX via ogr2ogr.
> The "default" conversion works well:
> <http://www.gdal.org/ogr/drv_gpx.html>$ ogr2ogr -f GPX nome_file.gpx
> nome_file.shp
> I'd like to mantain two attributes and I tried the option
> GPX_USE_EXTENSIONS=YES with sql instruction to rename the interested fields:
> $ ogr2ogr -f GPX -dsco GPX_USE_EXTENSION=YES -sql "SELECT NOME AS name,
> CAT AS desc FROM source_layer" nome_file.gpx nome_file.shp
> but I get this error:
> ERROR 1: SQL: Missing comma after column NOME in SELECT statement
> It seems that I forgot a comma but this command is the same in the
> documentation.
> I've checked the syntax with the help of this doc:
> http://www.gdal.org/ogr/drv_vrt.html
> but I don't understand where is the error.
> Does anibody have similar experience?
Flavio,
I found the above syntax worked in trunk, and 1.6 but not in 1.5.  I suspect
you are using 1.5.x or earlier binaries that do not support the AS operator
for renaming fields.
Best regards,
