[gdal-dev] 1.7 release date
Cuinet Jérôme jerome at georezo.net
Wed Jun 10 14:39:41 EDT 2009
Now, I want to use a new enhancement which is not compile by defaut. So I
have downloaded trunk sources, compiled the files and so I have a local user
library (which is so in /usr/local/lib directory).
I'm using unstable trunk library ! Yes, I 'm using new enhancement ! I shall
discover new bugs ! Yes, I should eradicate these !
It may be the open's magic. Elsewhere, I must wait and just ask when such
feature will be released, and I will have to pay the library...
New early releases might be useless. Be patient.
----- Original Message -----
To: <gdal-dev at lists.osgeo.org>
Sent: Wednesday, June 10, 2009 8:11 PM
Subject: Re: [gdal-dev] 1.7 release date
> On Wed, Jun 10, 2009 at 12:29 PM, Even Rouault
> <even.rouault at mines-paris.org
>> wrote:
>> 1.7 release date hasn't been decided yet. There is no precise criterion
>> to
>> determine when it happens : it depends mainly on when RFC or major work
>> planned by developers have been implemented. But if you look at the
>> release
>> date of previous "major" versions (1.6.0 ~ 04-Dec-2008, 1.5.0 ~
>> 20-Dec-2007,
>> 1.4.0 ~ 5-Jan-2007), you could expect 1.7.0 for the end of 2009.
> Good to know.
>> Depending on the bug fix (which one are you refering to ? ticket number,
>> SVN
>> revision), it could be considered to be backported into the next
>> maintenance
>> version of the 1.6.x branch. But 1.6.1 has been released just a few weeks
>> ago, so 1.6.2 won't likely be released before a few months.
> I'm looking at ticket #2989.  See: http://trac.osgeo.org/gdal/ticket/2989
> I'll likely end up creating a patch for my gentoo ebuild unless this gets
> backported into a 1.6.2 release.  It's tough to deal with some of the new,
> large GeoEye-1 scenes without this fix.
> Thanks,
> Matt
> gdal-dev mailing list
