[gdal-dev] TypeError: in method 'Dataset_GetRasterBand', argument 2 of type 'int'
Vincent Schut schut at sarvision.nl
Fri Jun 12 03:26:32 EDT 2009
Folks,
since some days (I have upgraded both gdal (refreshed from trunk) and
numpy (trunk), and maybe even swig) I get swig related errors from the
python gdal bindings when passing an element from a numpy array to a
gdalpython function that expects an int, like:
the type that is being passed here is <type 'numpy.int64'>. So indeed
this is no true pythonic int, rather a numpy type, though it can be
regarded as an integer. Now I know this used to work before, I just
don't know what changed where to make it not work. Gdal? Numpy? Swig?
It's easy to circumvent by adding a int(...) where necessary, but it's
rather inconvenient.
I decided to first try the gdal ml. If it's not gdal's fault, I'll try
the numpy folks ofcourse.
Vincent.
