[gdal-dev] hdf5 to esri shape-file converter
Chandra Shekhar Kumar
chandra.kumar at flagstonere.bm
Wed Jun 17 11:09:14 EDT 2009
I was looking for a converter tool to convert a given hdf5 file (.mh5)
to esri shape-files(.shp) and vice versa.
Does anyone has any idea about the same?
Does anyone see any utility in developing this(if it doesn't exists
already somewhere)?
Thanks,
Chandra
This communication contains information which is confidential and may also be legally privileged. It is for the exclusive use of the intended recipient(s). If you are not the intended recipient(s), disclosure, copying, distribution, or other use of, or action taken or omitted to be taken in reliance upon, this communication or the information in it is prohibited and maybe unlawful. If you have received this communication in error please notify the sender by return email, delete it from your system and destroy any copies.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090617/874a551c/attachment.html
