[gdal-dev] python CreateCopy just one band
Even Rouault even.rouault at mines-paris.org
Wed Jun 17 17:53:07 EDT 2009
Le Wednesday 17 June 2009 23:17:42 Gong, Shawn (Contractor), vous avez écrit :
> hi list,
> I use these codes for CreateCopy()
>     src_ds = gdal.Open( src_filename )
>     dst_ds = driver.CreateCopy( dst_filename, src_ds, 0 )
> If the src_ds has two bands and my dst_ds has only one band, is there a
> way to CreateCopy just one band?
No, not directly. Not even in C/C++ GDAL
> Or is there a way to remove bands in
> Gdal Python?
No, not even in C/C++ GDAL
But... you could create a VRT file that just references one band of your
source raster and use CreateCopy from it. Below I've written a sample script
that should do what you want to do. The vrt_xml has been deduced by observing
the output of "gdal_translate -of VRT -b 1 rgbsmall.tif rgbsmall_red.vrt" and
generalizing it a bit. It does the basic stuff (copy georeferencing and pixel
values), but it should be improved if you want to copy metadata, color table,
etc
#!/usr/bin/python
import gdal
src_filename = "rgbsmall.tif"
dst_filename = "rgbsmall_red.tif"
band_list = [1]
xsize = src_ds.RasterXSize
ysize = src_ds.RasterYSize
gt = src_ds.GetGeoTransform()
srs = src_ds.GetProjectionRef()
vrt_xml = '''<VRTDataset rasterXSize="%d" rasterYSize="%d">
    <SRS>%s</SRS>
    <GeoTransform>%f, %f, %f, %f, %f, %f</GeoTransform>''' % \
     (xsize, ysize, gdal.EscapeString(srs, scheme = gdal.CPLES_XML), \
      gt[0], gt[1], gt[2], gt[3], gt[4], gt[5])
dst_band = 1
for src_band in band_list:
    data_type = src_ds.GetRasterBand(src_band).DataType
    data_type_name = gdal.GetDataTypeName(data_type)
    vrt_xml = vrt_xml + '''
    <VRTRasterBand dataType="%s" band="%d">
        <SimpleSource>
        <SourceFilename relativeToVRT="1">%s</SourceFilename>
        <SourceBand>%d</SourceBand>
        <SrcRect xOff="0" yOff="0" xSize="%d" ySize="%d"/>
        <DstRect xOff="0" yOff="0" xSize="%d" ySize="%d"/>
        </SimpleSource>
    </VRTRasterBand>''' % \
    (data_type_name, dst_band, src_filename, src_band, \
     xsize, ysize, xsize, ysize)
    dst_band = dst_band + 1
</VRTDataset>'''
vrt_ds = gdal.Open(vrt_xml)
driver = gdal.GetDriverByName('GTiff')
dst_ds = driver.CreateCopy( dst_filename, vrt_ds )
> thanks,
> Shawn
