[gdal-dev] DTED Level 1 to Level 0
Aaron Brown aaron.j.brown at hotmail.com
Mon Jun 22 09:32:56 EDT 2009
Hi Frank,
Thanks for the fast reply and also attaching a subject line, i forgot all about that... :S
I had read that link before and i understand the basic differences between DTED levels 0 and 1 however I'm truely stuck at where to start.  The task was given to me by a co-worker when I was telling him about my interest in learning to program when I stumbled across gdal.  I have read various documentation on gdal but still don't fully understand how to use it.  Would you be able to point me towards some useful examples?
I'm not sure how to specify which DTED level you wish to write, however I did try "gdal_translate -of DTED DTED/E150/S22.DT1 DTED/E150/S22.DT0" however i'm fairly certain the output was really DTED Level 1.
Any help is appreciated.
Regards,
Aaron
> Date: Sun, 21 Jun 2009 10:43:47 -0400
> From: warmerdam at pobox.com
> To: aaron.j.brown at hotmail.com
> CC: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] DTED Level 1 to Level 0
> Aaron Brown wrote:
> > Hi all,
> > I have to convert DTED Level 1 data into DTED Level 0 data, and was just
> > wondering if anyone would be able to help?
> Aaron,
> I have taken the liberty of attaching a related subject line for this email.
> What have you tried so far?  Have you read the DTED drive documentation
> yet?  Are you fine with doing the conversion using gdal_translate?
>    http://www.gdal.org/frmt_dted.html
> It should be doable, but I'd like to know you have made an effort and that
> I'm not going to explain stuff you have already tried before I sink a bunch
> of time into this.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
_________________________________________________________________
View photos of singles in your area Click Here
http://dating.ninemsn.com.au/search/search.aspx?exec=go&tp=q&gc=2&tr=1&lage=18&uage=55&cl=14&sl=0&dist=50&po=1&do=2&trackingid=1046138&r2s=1&_t=773166090&_r=WLM_EndText
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090623/52e4ee22/attachment.html
