[gdal-dev] convert kmz to shapefiles
Matthew Snape SnapeM at rpsgroup.com
Wed Jun 24 08:09:51 EDT 2009
Have you tried decompressing the kmz and then converting the doc.kml?
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of maning sambale
Sent: 24 June 2009 11:00
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] convert kmz to shapefiles
I tried converting kmz (compressed kml) to shapefile but it is not
recognized by ogr2ogr.  Any workaround the list can suggest?
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
This e-mail message and any attached file is the property of the sender and is sent in confidence to the addressee only. The contents are not to be disclosed to anyone other than
the addressee. Unauthorised recipients are requested to preserve this confidentiality and to advise the sender immediately of any error in transmission. If you experience difficulty
with opening any attachments to this message, or with sending a reply by email, please telephone on + 44-(0)1235 438151 or fax on + 44-(0)1235 438188.
Any advice contained in this e-mail or any accompanying file attached hereto is for information purposes only. RPS do not take any responsibility for differences between the original
and the transmission copy or any amendments made thereafter. If the addressee requires RPS to be responsible for the contents of this e-mail, RPS will be pleased to issue a signed
hard copy of the document upon request.
RPS Planning and Development Limited, company number: 02947164 (England). Registered office: Centurion Court, 85 Milton Park Abingdon Oxfordshire OX14 4RY.
RPS Group Plc web link: <http://www.rpsgroup.com>
