[gdal-dev] convert kmz to shapefiles
Christopher Condit condit at sdsc.edu
Thu Jun 25 16:09:04 EDT 2009
Hi Maning-
> I tried to decompress the kmz nd converted the doc.kml.  ogr2ogr did
> not convert the kml (for good reasons) because it is a mixture of
> placemark, polygons and lines
This is a known limitation of the current driver. I would suggest rearranging your data into layers comprised of only one type of Geometry and trying that...
-Chris
