[gdal-dev] RADARSAT2 NITF RPC georeferencing
Even Rouault even.rouault at mines-paris.org
Sun Jun 28 13:29:38 EDT 2009
Le Thursday 25 June 2009 22:04:58 Gong, Shawn (Contractor), vous avez écrit :
> hi list,
> RSAT2's NITF product comes in "imagery_##.ntf" and "product.xml"
> gdalinfo output for these two are listed below.
> Georeferencing is off between the two files (their corners don't match
> using OpenEV).
> Q1: Is it true that imagery_##.ntf uses affine transform (see
> GeoTransform tag), and product.xml uses 143 GCPs?
For what I know, NITF files can contain only 4 GCPs and the NITF driver tries
to compute a GeoTransform from those 4 ones.
> Q2: I see that NITF RPC georeferencing has been implemented,
> http://trac.osgeo.org/gdal/wiki/rfc22_rpc  How do I use the RPC in
> RADARSAT2's NITF file? Will the RPC provide better georeferencing?
You can use the RPC info by using the '-rpc' option of gdalwarp.
> thanks,
> Shawn
> imagery_##.ntf
> Driver: NITF/National Imagery Transmission Format
> Files: imagery_HH.ntf
> Size is 8792, 10070
> Coordinate System is:
> GEOGCS["WGS 84",
>     DATUM["WGS_1984",
>         SPHEROID["WGS 84",6378137,298.257223563,
>             AUTHORITY["EPSG","7030"]],
>         TOWGS84[0,0,0,0,0,0,0],
>         AUTHORITY["EPSG","6326"]],
>     PRIMEM["Greenwich",0,
>         AUTHORITY["EPSG","8901"]],
>     UNIT["degree",0.0174532925199433,
>         AUTHORITY["EPSG","9108"]],
>     AUTHORITY["EPSG","4326"]]
> GeoTransform =
>   50.03718817626492, 5.656037108659124e-005, 1.153154346122985e-005
>   13.76523037807838, 1.126467725830654e-005, -5.535416735635244e-005
> Metadata:
>   NITF_FHDR=NITF02.10
>   NITF_CLEVEL=06
>   NITF_STYPE=BF01
>   NITF_OSTAID=RSI
>   NITF_FDT=20081019203042
>   NITF_FTITLE=RS2_RECTIFIED:2008-10-19T14:51:25.306614Z
> RPC Metadata:
>   LINE_OFF=5034
>   LINE_SCALE=5036
>   SAMP_OFF=4388
>   SAMP_SCALE=4538
>   LONG_OFF=50.3435
>   LONG_SCALE=0.3068
>   LAT_OFF=13.5359
>   LAT_SCALE=0.3283
>   HEIGHT_OFF=0
>   HEIGHT_SCALE=700
>   LINE_NUM_COEFF=0.0006728793 0.2105967 -1.130644 -1.223845e-006
> -0.0003698973 -1.002738e-007 -3.118422e-007 -0.0006155271 -0.000504439 0
> -1.174964e-008 2.143919e-007 -4.856652e-006 7.659651e-008 -6.164503e-006
> -8.210502000000001e-007 -4.267789e-007 -4.321238e-008 0 -2.272615e-008
>   LINE_DEN_COEFF=1 -0.0004301605 0.0002676128 -3.302012e-007
> -3.970334e-006 0 1.027667e-008 -6.566892e-006 2.541771e-006
> 3.784513e-007 0 0 -1.749914e-006 0 3.37938e-007 3.157953e-006 0 0 0 0
>   SAMP_NUM_COEFF=0.0003633695 1.147341 0.2557103 -0.03114342
> -0.0006508754 0.0008477953 0.0001658026 -5.388591e-005 -0.0002000257
> 2.006948e-005 -1.95455e-005 -2.907722e-006 -9.035467999999999e-006
> -1.276494e-006 1.372415e-006 -1.699765e-006 -5.031646e-007
> -6.214799e-005 -1.609981e-006 3.722058e-008
>   SAMP_DEN_COEFF=1 -0.0001622142 0.0007102185 -0.001001374
> -8.652518e-007 4.728022e-005 1.732678e-005 -2.196369e-006 8.936224e-006
> -1.514486e-006 -2.812931e-006 0 1.072109e-007 1.4604e-007 -1.900576e-008
> -2.564915e-007 0 -6.090468e-006 -3.221172e-007 0
>   MIN_LONG=50.1901
>   MAX_LONG=50.4969
>   MIN_LAT=13.37175
>   MAX_LAT=13.70005
> Corner Coordinates:
> Upper Left  (  50.0371882,  13.7652304) ( 50d 2'13.88"E, 13d45'54.83"N)
> Lower Left  (  50.1533108,  13.2078139) ( 50d 9'11.92"E, 13d12'28.13"N)
> Upper Right (  50.5344670,  13.8642694) ( 50d32'4.08"E, 13d51'51.37"N)
> Lower Right (  50.6505896,  13.3068530) ( 50d39'2.12"E, 13d18'24.67"N)
> Center      (  50.3438889,  13.5360417) ( 50d20'38.00"E, 13d32'9.75"N)
> Band 1 Block=1024x1024 Type=UInt16, ColorInterp=Gray
> product.xml
> Driver: RS2/RadarSat 2 XML Product
> Files: product.xml
>        lutBeta.xml
>        lutSigma.xml
>        lutGamma.xml
>        imagery_HH.ntf
>        imagery_HV.ntf
> Size is 8792, 10070
> Coordinate System is `'
> GCP Projection = GEOGCS[,DATUM[,SPHEROID["WGS
> 1984",6378137,298.2572235629972]],PRIMEM["Greenwich",0],UNIT["degree",0.
> 0174532925199433]]
> GCP[  0]: Id=1, Info=
>           (0,0) -> (50.0368241447173,13.7652233850433,0)
> GCP[  1]: Id=2, Info=
>           (879.099976,0) -> (50.0866031135979,13.775165475226,0)
> GCP[  2]: Id=3, Info=
>           (1758.19995,0) -> (50.1363862930026,13.7850974953681,0)
> GCP[  3]: Id=4, Info=
>           (2637.30005,0) -> (50.1861736889333,13.7950194384848,0)
> GCP[  4]: Id=5, Info=
>           (3516.3999,0) -> (50.2359652797982,13.8049312921043,0)
> GCP[  5]: Id=6, Info=
>           (4395.5,0) -> (50.2857610923955,13.8148330533982,0)
> GCP[139]: Id=140, Info=
>           (6153.7002,10069) -> (50.5012171146149,13.2772541435474,0)
> GCP[140]: Id=141, Info=
>           (7032.7998,10069) -> (50.5509029539819,13.2871595011868,0)
> GCP[141]: Id=142, Info=
>           (7911.8999,10069) -> (50.6005928456264,13.297055157266,0)
> GCP[142]: Id=143, Info=
>           (8791,10069) -> (50.6502867615454,13.3069410980946,0)
> Metadata:
>   PRODUCT_TYPE=SGF
>   PIXEL_SPACING=6.25000000e+00
>   LINE_SPACING=6.25000000e+00
>   BETA_NOUGHT_LUT=lutBeta.xml
>   SIGMA_NOUGHT_LUT=lutSigma.xml
>   GAMMA_LUT=lutGamma.xml
>   SATELLITE_IDENTIFIER=RADARSAT-2
>   SENSOR_IDENTIFIER=SAR
>   BEAM_MODE=F1
>   ACQUISITION_START_TIME=2008-10-19T14:51:24.966569Z
>   NEAR_RANGE_INCIDENCE_ANGLE=3.68685226e+01
>   FAR_RANGE_INCIDENCE_ANGLE=3.98800888e+01
>   SLANT_RANGE_NEAR_EDGE=9.631139343954010e+05
> Subdatasets:
>   SUBDATASET_3_NAME=RADARSAT_2_CALIB:BETA0:product.xml
>   SUBDATASET_3_DESC=Beta Nought calibrated
>   SUBDATASET_2_NAME=RADARSAT_2_CALIB:SIGMA0:product.xml
>   SUBDATASET_2_DESC=Sigma Nought calibrated
>   SUBDATASET_4_NAME=RADARSAT_2_CALIB:GAMMA:product.xml
>   SUBDATASET_4_DESC=Gamma calibrated
>   SUBDATASET_1_NAME=RADARSAT_2_CALIB:UNCALIB:product.xml
>   SUBDATASET_1_DESC=Uncalibrated digital numbers
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0,10070.0)
> Upper Right ( 8792.0,    0.0)
> Lower Right ( 8792.0,10070.0)
> Center      ( 4396.0, 5035.0)
> Band 1 Block=1024x1024 Type=UInt16, ColorInterp=Undefined
>   Metadata:
>     POLARIMETRIC_INTERP=HH
> Band 2 Block=1024x1024 Type=UInt16, ColorInterp=Undefined
>   Metadata:
>     POLARIMETRIC_INTERP=HV
