[gdal-dev] Trouble installing gdal 1.6.1
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Jun 30 11:40:43 EDT 2009
Adeel Raza wrote:
> Hi Jeff,
> Thanks for replying. I set the MSVC_VER variable in the original command
> to compile the library as follows:
> D:\gdal-1.6.1> nmake /f makefile.vc MSVC_VER=1500
> But it seemed like that had no effect  "nmake.opt". So i just changed it
> manually and the install command is working now. But I do appreciate
> your reply. Thanks.
I am referring to setting the MSVC_VER variable in nmake.opt on line
~26.  Set it there, save it, and retry your tests.
(please always reply to the gdal mailing list..or you can email me
directly for my support rates)
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
