[gdal-dev] PackBitsDecode: Not enough data ...
Even Rouault even.rouault at mines-paris.org
Tue Jun 30 16:03:26 EDT 2009
Does gdalinfo -checksum lceugr100_00_pct_epsg4326.tif works ? If it doesn't,
you might want to try with a recent GDAL (e.g 1.6.1) and internal libtiff
support.
Le Tuesday 30 June 2009 16:06:52 Hermann Peifer, vous avez écrit :
> Hi.
> I am trying to warp a GeoTiff from EPSG:3035 to EPSG:4326. After 50%
> done, I end up with the following errors:
> $ gdalwarp -t_srs EPSG:4326 lceugr100_00_pct.tif
> lceugr100_00_pct_epsg4326.tif -co COMPRESS=PACKBITS
> Copying color table from lceugr100_00_pct.tif to new file.
> Creating output file that is 121261P x 44229L.
> Processing input file lceugr100_00_pct.tif.
> 0...10...20...30...40...50..ERROR 1:
> lceugr100_00_pct_epsg4326.tif:PackBitsDecode: Not enough data for
> scanline 22054
> ERROR 1: TIFFReadEncodedStrip() failed.
> ERROR 1: IReadBlock failed at X offset 0, Y offset 22054
> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 22054
> Is there any issue with the decoding the PACKBITS compression?
> Hermann
> $ gdalinfo lceugr100_00_pct.tif
> Driver: GTiff/GeoTIFF
> Files: lceugr100_00_pct.tif
>         lceugr100_00_pct.aux
> Size is 67000, 58000
> Coordinate System is:
> PROJCS["ETRS_1989_LAEA_L52_M10",
>      GEOGCS["GCS_ETRS_1989",
>          DATUM["European_Terrestrial_Reference_System_1989",
>              SPHEROID["GRS_1980",6378137.0,298.257222101]],
>          PRIMEM["Greenwich",0.0],
>          UNIT["Degree",0.0174532925199433]],
>      PROJECTION["Lambert_Azimuthal_Equal_Area"],
>      PARAMETER["False_Easting",4321000.0],
>      PARAMETER["False_Northing",3210000.0],
>      PARAMETER["Central_Meridian",10.0],
>      PARAMETER["Latitude_Of_Origin",52.0],
>      UNIT["Meter",1.0]]
> Origin = (800000.000000000000000,6500000.000000000000000)
> Pixel Size = (100.000000000000000,-100.000000000000000)
> Metadata:
>    AREA_OR_POINT=Area
> Image Structure Metadata:
>    COMPRESSION=PACKBITS
>    INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (  800000.000, 6500000.000) ( 72d48'20.05"W, 59d 5'6.85"N)
> Lower Left  (  800000.000,  700000.000) ( 24d 7'20.21"W, 22d12'54.64"N)
> Upper Right ( 7500000.000, 6500000.000) ( 90d22'56.28"E, 61d55'58.94"N)
> Lower Right ( 7500000.000,  700000.000) ( 41d 0'50.13"E, 23d29'5.23"N)
> Center      ( 4150000.000, 3600000.000) (  7d17'47.28"E, 55d28'33.08"N)
> Band 1 Block=67000x1 Type=Byte, ColorInterp=Palette
>    Metadata:
>      LAYER_TYPE=thematic
>    Color Table (RGB with 256 entries)
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
