[gdal-dev] Bigtiff question
Lucena, Ivan ivan.lucena at pmldnet.com
Thu Mar 5 10:12:26 EST 2009
Hi there,
I am running a Python script that goes through a relatively large number of single band raster files (320) and aggregates it in a big-geotiff (around 7Gb) and I am facing three basic problems *poor performance*,
*wrong results*" and *lost of metadata*.
I need that geotiff to be interleaved by pixel since the goal is to query for historical values in a given location and return then in the best response time possible.
So I am using this create options:
    driver_tif = gdal.GetDriverByName("GTIFF")
    output_dst = driver_tif.Create( output_tif, x_size, y_size, serie_count, data_type,
        [ 'TILED=NO', 'INTERLEAVE=PIXEL' ])
I also need to add custom metadata entries to the dataset and to the individuals bands so that we know their data stamps.
That is how I loop to all the files and copy then to the output big-geotiff file:
    gdal.SetCacheMax(500)
    count = 1
    for i in list_tsf:
        input_dst = gdal.Open( f )
        input_band  = input_dst.GetRasterBand( 1 )
        output_band = output_dst.GetRasterBand( count )
        output_band.WriteRaster( 0, 0, x_size, y_size, input_band.ReadRaster( 0, 0, x_size, y_size ) )
        output_band.FlushCache()
        count = count + 1
*Performance*: The process takes more than 6 hours.
(Wrong Results*: All the pixels are zero (0)
If I just change the script on 'INTERLEAVE=PIXEL' to 'INTERLEAVE=BAND' the whole process takes around 30 minutes.
I can then use gdal_translate to convert from GTIFF to GTIFF with -co 'INTERLEAVE=PIXEL'. That takes another 30 minutes.
*Lost Metadata*: That looks like a solution except that I will then loose all my custom metadata entries.
Does anybody have any idea to improve that process.
Thanks is advance,
Ivan
