Re: [gdal-dev] Bigtiff question
Lucena, Ivan
ivan.lucena at pmldnet.com
Thu Mar 5 14:45:49 EST 2009
Even,
> for the very poor performance when dealing with pixel interleaved GTiffs with
> a large number of bands, I think you've hit ticket #2838 that has been fixed
> 3 weeks ago in trunk and branches/1.6 (*). The performance issue was about
> *reading* in such files, but sometimes when you write and the block cache
> size is not big enough, you also end up reading back partially written
> scanlines. Hopefully this would correct the problem you observe.
Ah!
> But as Frank suggested, I would not recommand using pixel interleaved GTiffs
> with a large number of bands anyway. This is fine for RGB or RGBA datasets,
> but for more bands, it could cause cache trashing problems as we prefill the
> blocks for all bands in pixel-interleaved mode (#2838 was about the fact this
> technic wasn't correctly implemented)
What raster format would you suggest then?
I mean, based on those requirements:
- Multiband;
- Large files;
- Good performance *reading* the data in pixel space. Not the "band as usual" ;)
> #!/usr/bin/python
> import gdal
> driver_tif = gdal.GetDriverByName("GTIFF")
> output_dst = driver_tif.Create( 'test.tif', 20, 20, 320, gdal.GDT_Byte,
> [ 'TILED=NO', 'INTERLEAVE=PIXEL' ])
> for i in range(320):
> output_band = output_dst.GetRasterBand( i + 1 )
> output_band.Fill(i + 1)
> output_band.FlushCache()
> output_dst = None
My real data is 5000x2500x312 Int16, can you try with:
output_dst = driver_tif.Create( 'test.tif', 5000, 2500, 312, gdal.GDT_Int16,
My best regards,
Ivan
