[Gdal-dev] HDF5 library
LFas
lucafasano at interfree.it
Fri Mar 6 12:33:05 EST 2009
Hi list,
I tried to create a dll only for hdf5 gdal files, i.e. 3 files in frmts/hdf5
which I modified.
I use MS Visual Studio 2008 and tried to do it with makfile.vc and obviously
included nmake.opt. Once I defined GDAL_ROOT, HDF5_DIR, SZIP_DIR, HDF5_LIB
as $(HDF5_DIR)\dll\hdf5dll.lib \ $(SZIP_DIR)\dll\szlibdll.lib , I done
nmake -f makefile.vc and it tells me the file "sys\types.h" cannot be found.
In fact it isn't present in hdf5 folder. Where I'm wrong?
Thanks
View this message in context: http://n2.nabble.com/HDF5-library-tp2437048p2437048.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
