[gdal-dev] Re: GDAL - CSharp
Tomas R monshi at home.se
Fri Mar 6 17:01:00 EST 2009
Tamas, remember the detective work done last year.
32 bit C# interface won't mix at all with 64 bit runtime environment. or
have you found a way around that? have not followed the list for some
time, just now trying to create a 64-bit version of gdal.
Yes, I have a problem too, and yes a q has been posted on this list.
/Tomas
Tamas Szekeres skrev:
> You should provide further info about your environment:
> 1. Did you test your app by running from an IDE like VS2005 for example?
> 2. What version of OS/IIS you intend to use when deploying the
> application.
> You appdir and platform configuration (32/64) may be different
> depending on your environment.
> For example by using the VS IDE you'd probably use
> WebDev.WebServer.exe as the host process which is running against the
> 32 bit version of the .NET framework on a 64 bit machine.
> You might want to use SysInternals ProcMon.exe to make sure about the
> expected locations of the dll files.
> Best regards,
> Tamas
> 2009/2/12 Tri <rsosnowski at cableone.net <mailto:rsosnowski at cableone.net>>
>     Tamas,
>     I'm creating web services.  This is first go on 64 bit machine -
>     plenty of
>     32 bit web services to fall back on.  The problem is I was using
>     FDO which
>     as far as I know has only 32 bit compiled code.  So I set the
>     'Enable 32 Bit
>     Application' to true, published the application, then tried to run
>     from
>     localhost.  There were no problems with 64 bit, 32 bit conflicts
>     this way.
>     However, I then started getting an error that says:
>     System.IO file not found.   I'm not using System.IO file in the
>     web service.
>     So, I thought I would use your compiled 64 bit GDAL / OGR code to
>     create a
>     new web service, but running into previously mentioned problem
>     taking this
>     approach.
>     Thanks again.....
>     Tamas Szekeres wrote:
>     > What kind of application you develop  Console/WinForms/ASP.NET
>     <http://ASP.NET> ?
>     > Wouldn't it be sufficient to use 32 bit binaries and compile
>     your app with
>     > the /platform:x86 option?
>     > Best regards,
>     > Tamas
>     >> Hi Tamas and others - thanks for the help.
>     >> By application executing directory - I've copied the files to
>     both the
>     >> bin
>     >> directory under the project and the obj, Debug directory under the
>     >> project.
>     >> When I run the application in debug mode, the same problem occurs:
>     >> System.TypeInitializationException:   The type initializer for
>     >> OSGeo.OGR.Ogr
>     >> threw an exception
>     >> InnerException:   The type initializer for OSGeo.OGR.OgrPINVOKE
>     threw an
>     >> excpetion
>     >> I am using the 64 bit compiled code from you on Vista 64 bit
>     machine.
>     >> Any more ideas?  Thanks.....
>     >> > Hi,
>     >> > You might have to copy all of the dll-s (*_csharp.dll,
>     *_wrap.dll,
>     >> > gdal16.dll, proj.dll etc.) to the application executing
>     directory.
>     >> > Best regards,
>     >> > Tamas
>     >> > 2009/2/11 Tri <rsosnowski at cableone.net
>     >> >> Can't get GDAL / OGR to work with CSharp.  Using the CSharp
>     dlls, I
>     >> keep
>     >> >> getting exceptions like:
>     >> >> OgrPINVOKE, threw an exception.
>     >> >> TO TRY TO GET TO WORK I DID:
>     >> >> - Copied the csharp dlls into project,
>     >> >> - Created a reference to the dlls.
>     >> >> What am I doing wrong?
>     >> >> View this message in context:
>     >> >> http://n2.nabble.com/GDAL---CSharp-tp2308674p2308674.html
>     >> >> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>     >> >> _______________________________________________
>     >> >> gdal-dev mailing list
>     >> >> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     >> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>     >> http://n2.nabble.com/GDAL---CSharp-tp2308674p2312047.html
>     http://n2.nabble.com/GDAL---CSharp-tp2308674p2312090.html
