[gdal-dev] Re: GDAL - CSharp
Tomas R
monshi at home.se
Fri Mar 6 18:01:32 EST 2009
2. No, not in my control. So I will make use of the 64 bit version where
necessary.
If you wish refresh your memory, look back to my question in this list
at 2008-02-29 with subject C#: Gdal on Win64
There you, somewhere in the thread, have provided an explanation
Yours
Tomas
Tamas Szekeres skrev:
> Hi Tomas,
> I don't remember what the exact problem was, however the situation
> remains the same, namely:
> 1. We can compile gdal either for x86 or x64. The x86 version could
> work natively with the x86 version on the .NET framework and the x64
> compilation would work with the x64 version of the framework.
> 2. If the host process is developed by you, then you should use the
> /platform:x86 compiler optionand use the gdal x86 compilation. This
> setting will provide to force your application to run on x86 mode
> regardless of the environment which will work pretty well on each
> platform then.
> 3. ASP.NET <http://ASP.NET> application running on a Win64 OS use the
> x64 framework by default, therfore you'll have to use the Win64
> compiled gdal binaries. However this is not the case when running the
> same application in the VS debugger since the debugger host process is
> running in x86 mode by default.
> Best regards,
> Tamas
> 2009/3/6 Tomas R <monshi at home.se <mailto:monshi at home.se>>
> Tamas, remember the detective work done last year.
> 32 bit C# interface won't mix at all with 64 bit runtime
> environment. or have you found a way around that? have not
> followed the list for some time, just now trying to create a
> 64-bit version of gdal.
> Yes, I have a problem too, and yes a q has been posted on this list.
> /Tomas
> You should provide further info about your environment:
> 1. Did you test your app by running from an IDE like VS2005
> for example?
> 2. What version of OS/IIS you intend to use when deploying the
> application.
> You appdir and platform configuration (32/64) may be different
> depending on your environment.
> For example by using the VS IDE you'd probably use
> WebDev.WebServer.exe as the host process which is running
> against the 32 bit version of the .NET framework on a 64 bit
> machine.
> You might want to use SysInternals ProcMon.exe to make sure
> about the expected locations of the dll files.
> Best regards,
> Tamas
> 2009/2/12 Tri <rsosnowski at cableone.net
> <mailto:rsosnowski at cableone.net>
> <mailto:rsosnowski at cableone.net>>>
> Tamas,
> I'm creating web services. This is first go on 64 bit
> machine -
> plenty of
> 32 bit web services to fall back on. The problem is I was
> using
> FDO which
> as far as I know has only 32 bit compiled code. So I set the
> 'Enable 32 Bit
> Application' to true, published the application, then tried
> to run
> from
> localhost. There were no problems with 64 bit, 32 bit
> conflicts
> this way.
> However, I then started getting an error that says:
> System.IO file not found. I'm not using System.IO file in the
> web service.
> So, I thought I would use your compiled 64 bit GDAL / OGR
> code to
> create a
> new web service, but running into previously mentioned problem
> taking this
> approach.
> Thanks again.....
> Tamas Szekeres wrote:
> > What kind of application you develop
> Console/WinForms/ASP.NET <http://ASP.NET>
> <http://ASP.NET> ?
> > Wouldn't it be sufficient to use 32 bit binaries and compile
> your app with
> > the /platform:x86 option?
> > Best regards,
> > Tamas
> >> Hi Tamas and others - thanks for the help.
> >> By application executing directory - I've copied the
> files to
> both the
> >> bin
> >> directory under the project and the obj, Debug directory
> under the
> >> project.
> >> When I run the application in debug mode, the same
> problem occurs:
> >> System.TypeInitializationException: The type
> initializer for
> >> OSGeo.OGR.Ogr
> >> threw an exception
> >> InnerException: The type initializer for
> OSGeo.OGR.OgrPINVOKE
> threw an
> >> excpetion
> >> I am using the 64 bit compiled code from you on Vista 64 bit
> machine.
> >> Any more ideas? Thanks.....
> >> > Hi,
> >> > You might have to copy all of the dll-s (*_csharp.dll,
> *_wrap.dll,
> >> > gdal16.dll, proj.dll etc.) to the application executing
> directory.
> >> > Best regards,
> >> > Tamas
> >> > 2009/2/11 Tri <rsosnowski at cableone.net
> >> >> Can't get GDAL / OGR to work with CSharp. Using the
> CSharp
> dlls, I
> >> keep
> >> >> getting exceptions like:
> >> >> OgrPINVOKE, threw an exception.
> >> >> TO TRY TO GET TO WORK I DID:
> >> >> - Copied the csharp dlls into project,
> >> >> - Created a reference to the dlls.
> >> >> What am I doing wrong?
> >> >> View this message in context:
> >> >> http://n2.nabble.com/GDAL---CSharp-tp2308674p2308674.html
> >> >> Sent from the GDAL - Dev mailing list archive at
> Nabble.com.
> >> >> _______________________________________________
> >> >> gdal-dev mailing list
> >> >> gdal-dev at lists.osgeo.org
> <mailto:gdal-dev at lists.osgeo.org>
> <mailto:gdal-dev at lists.osgeo.org>>
> >> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> >> http://n2.nabble.com/GDAL---CSharp-tp2308674p2312047.html
> >> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> http://n2.nabble.com/GDAL---CSharp-tp2308674p2312090.html
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
