[gdal-dev] FWTools 1.1.3 vs 2-0.6 gdal_translate
Dori
izzybitsie at gmail.com
Fri Mar 6 18:46:38 EST 2009
a while ago I wrote an application using gdal_translate to translate tags in
a geotiff image. I used the following command: gdal_translate -a_srs $tagfn
$infn $outfn where $tagfn is the file used to modify the tags, $infn is the
input filename and $outfn is the output file name (with the tags required).
I am running the same program with FWTools 2-0.6 on a new host.
I noticed by running the gdalinfo that there are significant differences in
Coordinate System between the 2 versions. I am no expert on the Geotiff
area so, I cannot comprehend what changes done to GDAL might be affecting
this translation.
Any idea on how to resolve this issue would be apreciated.
Thanks
Isidora
With 1.1.3*:
*Driver: GTiff/GeoTIFF
Files: WO_SATIR_00_21Z.tif_denwxp1
Size is 7479, 3033
Coordinate System is:
GEOGCS["unnamed",
DATUM["unknown",
SPHEROID["unretrievable - using WGS84",6378137,298.257223563]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]]
Origin = (-179.999899999999997,73.000000000000000)
Pixel Size = (0.048132577673166,-0.048139266469396)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
*With 2-0.6*
Size is 7479, 3033
LOCAL_CS["unnamed",
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Metadata:
AREA_OR_POINT=Area
INTERLEAVE=BAND*
*This is $tagfn:*
*Geotiff_Information:
Version: 1
Key_Revision: 1.0
Tagged_Information:
ModelTiepointTag (2,3):
0 0 0
-179.9999 73 0
ModelPixelScaleTag (1,3):
0.0481125224 0.0481125224 0
End_Of_Tags.
Keyed_Information:
GTModelTypeGeoKey (Short,1): ModelTypeGeographic
GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
GTCitationGeoKey (Ascii,8): "unnamed"
GeographicTypeGeoKey (Short,1): GCS_WGS_84
GeogCitationGeoKey (Ascii,8): "unnamed"
GeogAngularUnitsGeoKey (Short,1): Angular_Degree
ProjectedCSTypeGeoKey (Short,1): User-Defined
ProjectionGeoKey (Short,1): User-Defined
ProjCoordTransGeoKey (Short,1): CT_Equirectangular
ProjLinearUnitsGeoKey (Short,1): User-Defined
ProjLinearUnitSizeGeoKey (Double,1): 0.0174532925
ProjFalseEastingGeoKey (Double,1): 0
ProjFalseNorthingGeoKey (Double,1): 0
ProjCenterLongGeoKey (Double,1): 142
ProjCenterLatGeoKey (Double,1): 30
End_Of_Keys.
End_Of_Geotiff.
Projection Method: CT_Equirectangular
ProjCenterLatGeoKey: 30.000000 ( 30d 0' 0.00"N)
ProjCenterLongGeoKey: 142.000000 (142d 0' 0.00"E)
ProjFalseEastingGeoKey: 0.000000 m
ProjFalseNorthingGeoKey: 0.000000 m
GCS: 4326/WGS 84
Datum: 6326/World Geodetic System 1984
Ellipsoid: 7030/WGS 84 (6378137.00,6356752.31)
Prime Meridian: 8901/Greenwich (0.000000/ 0d 0' 0.00"E)
Corner Coordinates:
Upper Left ( -180.000, 73.000) (141d59'53.28"E, 0d 0' 2.36"N)
Lower Left ( -180.000, -73.022) (141d59'53.28"E, 0d 0' 2.36"S)
Upper Right ( 179.978, 73.000) (142d 0' 6.72"E, 0d 0' 2.36"N)
Lower Right ( 179.978, -73.022) (142d 0' 6.72"E, 0d 0' 2.36"S)
Center ( -0.011, -0.011) (141d60' 0.00"E, 0d 0' 0.00"S)*
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090306/058389cf/attachment-0001.html
