[gdal-dev] ogr2ogr changes attribute table after projection
Wesley Roberts
wroberts at csir.co.za
Tue Mar 10 03:07:04 EDT 2009
Dear Colleagues,
I have an ESRI shapefile with approximately 20 000 polygons in a geographic projection (WGS84). I have used the following command to convert the shapefile to a utm34s projection.
ogr2ogr wckznwimsextract_utm34s.shp wckznwimsextract.shp -t_srs EPSG:32734 -s_srs EPSG:4326
the coordinate transformation works perfectly however the attribute data in the new shapefile is incorrect. In fact very little of the original data is present, dates in the original data are now null (two different formats 2009-01-01 & 23-Mar-2008) with other text and numerical attributes also now removed. All columns from the original data are present but none of the original data remains.
If anyone could comment on this problem and or suggest a solution I would greatly appreciate it.
Many thanks and kind regards,
Wesley
Wesley Roberts MSc.
Researcher: Earth Observation (Ecosystems)
Natural Resources and the Environment
CSIR
Tel: +27 (21) 888-2490
Fax: +27 (21) 888-2693
"To know the road ahead, ask those coming back."
- Chinese proverb
This message is subject to the CSIR's copyright terms and conditions, e-mail legal notice, and implemented Open Document Format (ODF) standard.
The full disclaimer details can be found at http://www.csir.co.za/disclaimer.html.
This message has been scanned for viruses and dangerous content by MailScanner,
and is believed to be clean. MailScanner thanks Transtec Computers for their support.
